Old 11-15-2009, 01:34 AM   #246 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Christ View Post
So you obviously know your stuff on this... knew you did, by the way.
Small displacement long stroke, or high displacement short stroke? (Opinion) (Number of cylinders fixed to 5, for the sake of removing a variable.)
This is based on a 80mm bore with a 85mm stroke.
Pressure Gradient Force
The Positive Side of the Number Line
