yeah, driving on veggie oil sure does have more of an impact on the environment... burning it in engines releases glyceride compounds into the air, which are poisonous to the people breathing them in. sure, it's carbon neutral, but that doesn't change the fact that it has negative effects on the environment.
In case anyone thinks that glycerine gets burned in the engine, look up the combustion temperature for Glycerine... it's about 1,800*F, or ~1,000*C, and needs to be sustained there. Guess what temps your engine doesn't reach and sustain?
When brewing biodiesel Glycerine is a by-product, which can have many uses, including soap and fertilizer. After refining, it can also be used in medical fields.
