Old 11-16-2009, 11:33 PM   #22 (permalink)
Frank Lee
Originally Posted by thatguitarguy View Post
How did you do the joint between the seat post and handlebar stem on the two bikes?
Too bad I can't take a close-up pic of it right now. Basically I have the regular seat post clamp on the "his" seat post and another identical clamp with the bolt hole pointing forward on the handlebar stem- yes, luckily, the stem and the post are the same diameter. I cut two short pieces of angle iron from an old bed frame, drilled two holes, and bolted it together. Strap might work too but I had the angle iron so went for that in case it needed lateral strength.
Now that you have a description, maybe you can tell what you are looking at in the pics I have up already.
Adjusting the "seat" post on the "his" frame allows for crankset height/distance-from-seat adjustment.
