Originally Posted by aspera
I just played around with the calculator and then accidentally deleted my post.
I tried using drag area (because it is easier to find), speed and distance. I'm not sure what it means but I think I found a fun way to compare a Hummer and an Insight. I call it DRAG VOLUME.
The drag area for a Honda Insight is 5.10 sq ft.
The drag area for a Hummer H2 is 26.5 sq ft.
60mph is 5280 ft/min.
5.10 x 5280 = 26,928 (cubic feet/min?)
26.5 x 5280 = 139,920
The Hummer moves 26,928 (drag volume?) of air in a mere 1016 feet. If the Hummer goes 1016 feet per minute that's just 11.5 mph.
Sorry. I'm too dense to figure out what you are saying here.
Are you saying that at a mere 11.5 MPH a Dummer moves 26,928 cu.ft of air ?
( Imagine you are explaining yourself over again to a six year old. )
Thanks
