Old 11-17-2009, 08:55 PM   #1 (permalink)
SickMPGs
Crappy Gas Pipe - '84 Mercedes 300D Turbo 230k Miles
128 MPGe and now 4 sale
For Sale: 1984 Mercedes Benz 300D Turbo Diesel GreaseCar 244k
Yes this baby gets between 80 - 215 MPG diesel while commuting 110 miles round trip a day. I had the system in for three years and It works great! The engine purrs like a kitten but is like a Lion off the line. (turned up the IP screw) Comes with a filtration system that dewaters waste veg oil and filters down to 1 micron absolute. (Fryer to Fuel Base unit)Base WVO Filtration Unit at F2F Filtration Units I get 5k onboard Vegfilter life easy. Vegtherm standard w/ Vegsensor,Veg-Oil Temp gauge pre IP(red digital), 15 gallon heated VegTank in trunk. Spare tire still accessible. New tires in the front, A/C compressor, receiver drier/accumulator, expansion valve, R134A, A/C high low switch, all belts, brakes, alignment, motor mounts for engine and rear tranny, upper control arm, starter button, water pump, radiator, rear shock absorber, diesel primer pump(original style), hood release strap, Engine hood pad w/ heat shield over turbo unit, Aux fan and shroud cover, exhaust system, filters & fluids changed - rear diff fluid 85W140, Directional switch and relay, glow plugs, tie rods, struts, brakes and cali rebuild fall 2008,have all been replaced. Some rust spots and a tear in the drivers seat. CC works, AM/FM CD player, A/C new but doesn't work so well over 82*F when its sunny (No tinting). Asking $3k.
email: rfontanes@optonline.net Location: Long Island, NY
