Originally Posted by FastPlastic
So in that case the reason it only gets 180-300mpg's is because he forgets to top off the tank?
It's because you start up on straight diesel while the vegoil is warming up to the proper viscosity. And also because you switch to straight diesel before shutting down to purge the lines from vegoil.
I edited the thread title to reflect reality (MPGe, MPG alone was misleading).
