Old 11-20-2009, 11:31 AM   #6 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
What I do once every four months is run 1 liter of water through my engine.
It cleans the tops of the pistons and the combustion chambers of carbon build up.
I just hook a small vacuum hose from a 1 liter water bottle to a vacuum port on the intake and bring the engine rpm up 3000rpm so it won't stall. The engine will steam big time out the exhaust. I also pull all my O2 sensors so they won't be damaged.
Pressure Gradient Force
The Positive Side of the Number Line
