It seems like if you look hard enough you should be able to find a very small turbocharger that will work on a 125cc engine, the engine in it's stock form is around 12hp at 9,500rpm but it sees like a turbo would help with climbing hills and those other times when a little more power is needed while giving you the advantage of the small engine the rest of the time.
