Old 11-24-2009, 04:08 AM   #19 (permalink)
max_frontal_area
the OM617, the one with turbo makes 150hp @ nearly 5k! kkk makes a k26 turbo which is next size larger direct bolt on with integrated wastegate. the factory turbo was a bit too small therefore the high rpms required to make any power. mpg will also benefit from
a properly sized involute! some guy ran 26psi of boost for a long time without hurting
the engine... there is great potential with OM617
if you ever do any work on it port the head and look for an intake manifold off
another benz i can look up if you are interested.
intercool and consider water injection to manage your egts now that you are dragging around another 2-3k Lbs with 2x the CD to boot. do use ram air to feed your turbo if you make no other changes!
once you get it tuned you can expect some interesting MPG!
the 700t is it 4 or 5 speed, you made the adapter from scratch?
what did you do for a flywheel/clutch? do you have any pictures?
what kind of rear end do you have
i have been wanting to do this for a long time to an early 70's f-350....
