1) ATF
ATF has a lot of detergents in it. These break down or get used up over time. If you don't regularly change it, this adds a whole lot of cleaning properties to your fluid. This can disolve & dislodge a lot of gunk from inside your transmission. This loose gunk can clog small orifices & passageways as well as clog the filter. This can starve parts or all of the transmission of fluid. Some of the gunk may have been artificially sealing gaskets & seals. With this removed it may leak more.
I hate the idea of knowing I have crappy fluids in the car but I don't know what the proper fix for the situation is. Hopefully someone here does.
2) If it's had synthetic from day one I would leave it in it. If it starts leaking, you can change it then.
