Old 11-24-2009, 06:49 PM   #5 (permalink)
RandomFact314
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 28.73 mpg (US)
Originally Posted by TOOSTUBBORN2FAIL View Post
automatic or stick? im assuming this is on the neon
if its a stick, use Mobil 1 10w30 High Mileage ONLY! It is 99.7% the same as the correct mopar fluid according to oil analysis, and is the only oil other then the mopar fluid that has the right ingrediants to ensure long life for the synchros, which are made of a special material. 75w tranny oil will destroy the synchros in a neon.
Also, if its a stick, drain your fluid, and put the mobil 1 in, after 98, dodge decided to cut costs and put atf in the stick shift trannys. It works, but its a cheap bandaid fluid.
No its not a manual, its an auto 2000 dodge neon
