Old 11-25-2009, 02:34 AM   #2 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Certain aeromods also help warm-up times: a grille block and belly pan under the engine compartment. If you don't have those, then that's the first step.
Thermal insulation under the hood won't help much at the begining of warm-up, but it will keep the heat in after you stop, giving you a warmer engine if you come back within 1-2 hours.
