WOW that is some cool info. so if you do a 100% led replacement you can dramatically drop your night time electrical load. (I figured those 194's 1156';s 1157's drew a lot of power considering how danged hot they get)
so in theory a 100watt solar panel system should be enough to run pretty much everything especially since it will also charge while your sitting at work parked in the lot. VERY cool!
