Sounds like the known problem of burnt valves. It's a common issue since these cars are considered "disposable" instead of "priceless" and never maintained. I bought both my Metros with the same problem. After rebuilding the head in a matter of hours, both cars are running strong and getting awesome gas mileage.
Shifter bushings may be gummed up and will work after using it, or maybe the trans is low on lube. If it were me, I would jump on it especially if the undercarriage is rust free and solid. If you do not wish to take on a project and rebuild this little car with your own two hands, then don't buy it. If you are interested, let us know and I can supply you with numerous guides with pictures and help you fix the car.
I don't regret buying and rebuilding the 2 I have. They have already payed me back and then some.
GeoMetroforum.com - got mpg?
