Old 11-26-2009, 02:11 AM   #4 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Didn't you just have the head gasket replaced?
Did it just start doing this after the head gasket or was it doing it before?
I would check the lines to the map sensor and make sure there isn't any tears in them causing a improper map reading.
Also this sounds crazy but make sure that all the engine grounds are hook back up.
Pressure Gradient Force
The Positive Side of the Number Line
