Thread: NarrowerTires?
Old 11-27-2009, 06:47 AM   #14 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Swiftbow View Post
Interesting Capri. How is a load indices calculation performed? ........
Load Index is a quick, and easy way to express load carrying capacity.
There are several formulae for calculating the load carrying of a tire, but they are complex - and of course, it varies accoprding to inflation pressure. Usually load carrying capacity is published in the form of a table.
I explain that in more detail here:
Barry's Tire Tech
......The focus is a fairly light car so I was surprised that this tire wouldn't have the load capacity.........
I explain that also in the link, but the short version is "Over-design / Under-utilize" - meaning you should use tires (and other products) at less than their maximum capacity - and the further away from the maximum you are, the safer it is.
.....I'm also surprised that even with the tire filled to max it would give deformity degrading FE. 195 to 155 width is a substantial amount where deformation of that magnitude is surprising. BUT I really don't want to compromise safety, especially in a situation where I could harm someone else in what in the scheme of things ... is just a simple test.
Doug
The rolling resistance of a tire is directly proportional to its deflection, so ANY deflection has a consequence on fuel economy. And changing tire sizes changes the deflection. When it comes to fuel economy, going a smaller tire is the wrong direction. Larger tires (meaning larger load carrying capacity) have lower RR for a given load. However, this effect is pretty small and huge improvements should not be expected.
