Old 11-27-2009, 10:58 AM   #9 (permalink)
tscheerer
Here are some pics of the Insight as a beginning point for the project.
The front end is from another car, obviously, and like most of the car needs a lot of work. I will be getting a 8" ADC motor - Dual shaft (203-06-4001A), Curtis 400a controller, adapter and mid 90's GM manual trans as the driveline. One of the fun challenges will be mating the cv shafts from the GM trans to the hubs on the car. For power, the initial plan is to go with 72v and see how that does, can go up to 120v if space and weight allows. More to come...
ID:	4832   Click image for larger version
ID:	4833   Click image for larger version
ID:	4834   Click image for larger version
The Following User Says Thank You to tscheerer For This Useful Post:
IamIan (03-26-2011)
