Got my motor rpm sensor up and running today and began thinking of an rpm limiter circuit for the controller. What would you guys think about using an lm2917 frequency to voltage converter connected to the hardware overcurrent circuit in the revolt? It could be setup to drop out the pwm at a certain rpm with low component count. Quite important for myself with an 11" forklift motor.
