That really does look good.
Very futuristic.
Not sure how much airflow that you are getting at the back of the car*, but have you considered removing that spoiler ? ( which could be potentially spoiling your airflow .)
* Your back glass has a pretty steep angle, so you most likely have detached flow. Doing a tuft test would show where the separation is occurring.
A shelf spoiler could reattach the flow and give you less drag.
I'm wondering the same thing that Neil pointed out. Do you have the upper grill blocked ? Usually it is better to block the upper grill.
