Old 11-28-2009, 03:39 PM   #4 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by orange4boy View Post
I'm trying to figure out a way of describing this and writing a good thread title so other hybrid owners would understand. In the ICE crowd you would just call it an alternator delete and everyone gets it. The Prius is a different animal.
If I were doing it, I would probably approach using a step-up, power supply rated at say 600 W (~45 A @13.8 VDC). It would use a current regulating circuit to tickle the voltage up and displace the inverter load. As soon as the target current from the deep storage battery was reached, hold it there.
The advantage is you won't have to break any circuits and it should minimize worry about open-loop, voltage feedback. You may run into some feedback instability but current sense regulators at these voltages and current levels should be standard parts.
One risk is the slightly higher voltage may lead to incandescent lights being a little "bright" and possibly shorter life. ... Tradeoffs.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
