Originally Posted by winkosmosis
The back of those cargo carriers is usually a pretty flat surface. I know people are fond of saying "it would be better backwards".... No it wouldn't, not when a sheer front surface is slamming into the air, causing it to fan out.
Would you say a Prius is more aerodynamic going backward? No, so why say it about any other Kamm shape?
This one might not be so bad backward
Do you mean to say that it would be better? Mine is more or less shaped like the second one, although taller and wider and not nearly as long.
