Old 11-29-2009, 10:02 PM   #5 (permalink)
user removed
I was using a partial radiator block. When temps fell this fall I installed a cover over the lower grille opening. Black plastic that fits very tight and just about eliminates any air flow from the lower grille area.
I may add a partial radiator block, but for now blocking the lower radiator opening seems to work fine. Colder climates would probably benefit from radiator blocks but be careful and it might be a good idea to monitor radiator fan activity. Also do not block the area of the radiator that would restrict the flow of air when the fan comes on.
Threw some pics of the garage in for fun. My VX with less than 49 k original miles, and the Echo as well as the Insight.
regards
Mech
ID:	4864   Click image for larger version
ID:	4865   Click image for larger version
ID:	4866   Click image for larger version
