Chris -
Originally Posted by Chris D.
I can tell you guys this..
My usuall section where I'd throw my truck into coasting mode before a stop sign with nobody behind me usually got me down to 35mph by a certain section.. last night I was coasting down in that same area and I was at 40mph in that same section.. this is all from 45mph exactly..
maybe theres something to this?
Someone can describe a better test than me, but I would do this, with and without the skirts :
1 - Find a hill you can coast down in Neutral that has a 45 MPH speed limit, and won't put you over 50 MPH (so no one can get mad at you for speeding) max on the coast. Maybe this means starting at a lower point down the hill. The hill will need a nice long flat section of road at the bottom.
2 - Start from the same start point each time. Coast down to a rolling stop as many times as it takes to get a reliable average for distance, max MPH, and time. The idea is to show repeatability.
If the skirts work, all three of those variables should be greater than without the skirts.
I think the only problem is finding that hill.
CarloSW2
