I figure not, but are you willing to give it a shot? You don't have a grille block at all, right? So I figure that it will shunt flow a bit because the air will have to change directions, but it might also keep the air from getting in around the engine and creating the vortex under the hood... maybe help with aero a bit?
Just figured if you're willing to test it out, might be something to look into.
