Old 11-30-2009, 03:22 PM   #6 (permalink)
Greg Fordyce
Maybe I should have said 3p45s. That is I will have a single 120ah (3 x 40ah) string of 45 cells. Does that make sense ? The decision was due to there being no 120ah cells available from Hipower and also the smaller cells package better in the car. I should be able to get 36 in the spare wheel well, another 36 in the petrol tank area and the rest up front with the motor.
Just got the engine and gearbox out of the car today. I have already mated the Impulse 9 motor to another gearbox that I got. Tried the axle shafts in the gearbox and the one that goes past the motor is hitting the adapter plate, so a bit of filing required. Also the rubber CV boot is touching the side of the motor casing so have to do a bit of work there as well. The original engine was a 3 cylinder 800cc, more of a lawn mower engine really. So the Impulse 9 is a bit of a squeeze, but I am expecting some good results.
