Old 11-30-2009, 06:23 PM   #16 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.7 mpg (US)
Originally Posted by Swiftbow View Post
Do you know what temp the t-stat is opening for the 250Ninja? Kawasaki tends to use low temperature (160F) t-stats. If it's a low temperature, looking to mod to a higher temp will help the efficiency as well as motor longevity.
I also would think one of the silicone stick-on oil pan heaters would fit on the bottom of the 250? I saw one 125watt heater advertised at 2.5" x 4".
Doug
I may have to look into that. The radiator is blocked, but I wonder if the cold coolant flowing through is having an effect.
And I don't think that there are flat surfaces that large on the underside of the Ninja engine. I will check, though.
