Old 11-30-2009, 07:42 PM   #104 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by Christ View Post
The ABS sensor setup is a laser with a sprocket-like rotor.
No, it is a Hall effect sensor. Put a Volt meter on it and wave a piece of steel in front, you'll see pluses. The reason they need to be cleaned is that they collect Iron filings (Byproduct of Brake pads wearing on the Rotor) and throw off the magnetic field.
That said I see no reason that Hall effect sensor couldn't be used (unless they would be thrown off by the Magnetic (flux???) thrown off by the motor. They have 1/10th Degree Resolution on many engines when used as Cam, or Crank position sensors. They are cheap, easy to find, and pretty reliable.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
Christ (11-30-2009)
