Old 11-30-2009, 07:52 PM   #20 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by orange4boy View Post
For now I'm going to test it with my 12V batteries - 750 watt inverter - 50 amp switch-mode charger - 12V Prius. Some losses from the batteries there but it's all the same to the Prius.
Excellent approach. You'll get a rough-order feedback on the potential fuel savings without putting a lot of money in the project. If it looks good after and "A" "B" "A" test, then an optimized design makes sense.
In the meantime I should be on the lookout for some big-ass diodes and hopefully a similarly big-ass DC-DC. The diodes reside in the voltage regulators, yes? Or are they mounted on the alternator?
It varies. I was looking at Ebay and saw a Ford and Chyrsler external set set of 100 A diodes but I haven't checked Digikey, Allied and Mouser, yet. What really surprised me were some Schottky diodes. These have an unusually low forward voltage drop.
Is the diode simply wired in line with the Prius DC-DC main wire?
The 'ring' should be the direction the "+" charges exit. Just check it with a battery and VOM. The positive charges pass in the direction of the arrow towards the base.
. . .I'm going to need block heaters to get decent mileage in the winter here. I just did two trips to the Cove and back and the Km/100 bars traced a hyperbolic curve down from the cold drive to the warm.
In the USA we have to order block heaters from Canadian dealers.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
