Originally Posted by jedi_sol
In my old kammback thread, I was told the transition should be 10* to keep attached airflow. After building mine, i ended up with 13*, not sure if that is what affected my negative mpg readings.
BTW: my results: On a 100 mile roundtrip drive with cruise control set to 65mph. Ambient temperature both trips 61*F, filled up at 2:30pm both trips. Using the same gas pump.
without kammback = 45mpg
with kammback = 41mpg
*angry face* ![Mad](/forum/images/smilies/mad.gif)
Oh great... I sure hope I see results. As of right now I have $200.00 in material.
I can change the roof angle (its adjustable) from 8 degrees to 15 degrees. But when I get the sides and the under-tray part done and in-close it in I won't be able to change the angle anymore.
![Frown](/forum/images/smilies/frown.gif)
