Old 12-01-2009, 09:12 AM   #4 (permalink)
Jim Allen
5.4L Econo Box
Jim Allen's Avatar
Plugger - '05 Ford F-150HD 4x4 XL
This is a good point.
I find that cars/trucks with electronic throttles are hyper-sensative and the pedal slopes programmed in are designed to give more throttle response with less pedal movement, making them very touchy. I'm working on reprogramming that in my rig, but in the interim, have been thinking about some way to increase tension on the pedal.
With my F-150, if you take a deep breath, you can effect the throttle. Sneeze and you're doing 90! Seriously, most times I can manage good throttle control, you have to work pretty hard at it. Too hard, IMHO.
Jim Allen
The Frugal Four Wheeler and Farmer
My ultimate goal is not necessarily the highest mpg but to make my trucks more efficient configured as I need them.
Old Reliable '86 Ford F-250HD 4x4, 6.9L diesel
Red '00 Honda Accord Coupe, 3.0L V6, automatic
The Plugger '05 Ford F-150HD 4x4, Regular Cab, 8-ft bed, 8,200# GVW, 5.4L V8, automatic, 4.10:1 ratios, 285/70R-17D tires
