Old 12-01-2009, 11:14 AM   #76 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by MadisonMPG View Post
It's a motor from an electric skateboard, it has a pretty good grunt to it.
eXkate Powerboard Motorized Electric Skateboards
The motor is mounted to the rear wheels, I am planning on taking off the rear trucks, and sawing it in half, or just removing the other side that is not the drive wheel. Then using a lathe or something grind down the drive wheel to about 2/3 the diameter it is now. That should lower my top speed and give me plenty of grunt. I need to take it all apart and see how it is set before I do anything.
Yeah, gear it down ALOT... it's setup to do 9MPH on the skate board, which (due to gearing differences) would be insane on a standard bike sprocket.
