Old 12-01-2009, 01:11 PM   #6 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Automatic Radiator Adjust
Some of the university students who design, build, and race SAE formula cars, have mentioned something that would help in this situation.
Consider that 1/3 of the engine heat goes to the radiator at what ever throttle position the engine is running at.
If you are pulling a large load up a pass in Colorado, and the engine is putting out 200 hp, then the radiator will need to dissipate 1/3 of that load, or 67 hp!! AND the hole for the radiator block needs to be sized accordingly.
Likewise if you are putting along on flat back roads, and only using 3 hp, then the radiator opening can be effectively closed-off completely.
The only way to safely do this, is provide an 'automatic' device that monitors this for you, or at least have a cable assisted damper or some sort.
Hope this helps, Jim.
