Old 12-01-2009, 07:59 PM   #27 (permalink)
Cd
Ultimate Fail
Cd's Avatar
By the way, the angles on the picture that I did are a little off on the 'ideal' underside angle ( pretty sloppy too), but I was trying to see how short I could make the tail, yet have it look esthetically pleasing.
If you have your car lowered, you may not get that much air under there anyways.
The angles on the sides ( the top view ) should be the 'ideal' angle though.
( I did an overlay of the teardrop template. )
Interestingly enough, the sides of you car already start to taper at just the right angle !
All you have to do is just add to that.
