Originally Posted by thatguitarguy
And if you spend much time moving all that lead around, you could grow up to be the governor of California (if you have an accent)
No Thanks, California is broke and burnin! Anyway, after I got them into
the battery box, that was enough. I wanted to use sams club 8v for the rest.
Those 113lb monsters are still holding charge. after two months of sitting.
Pretty good for used. Watt
