Originally Posted by Frank Lee
If the fan is running more you are kind of defeating the purpose of blocking in the first place.
Why do you say that? How much power does a fan use? If you're getting the same cooling with a smaller grill block, you will still improve efficiency if the drag decrease offsets the fan wattage.
