Old 12-01-2009, 11:56 PM   #9 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
That's gonna be a tight fit... The D series engine is only some 16-18 inches block length, and there's only another 2-3" of clearance in front of the engine before you hit the frame rails.
You may be able to move the electric motor slightly inside the transmission bell housing, but I wouldn't count on it fitting easily.
The front track width of the car is only 57.1", and the trans comes about to the middle of the car in the front, so you've only got ~30" left, and at least 10" of that is frame and fender clearance areas.
Consider a smaller trans to swap in, or a smaller motor.
The Following User Says Thank You to Christ For This Useful Post:
paker (12-02-2009)
