Old 12-02-2009, 07:10 AM   #84 (permalink)
Daox
Its made to coast in neutral, no problems there. The engine will kick in if you exceed max speed. However, if you just use the gas pedal you should be able to shut the engine off pretty easily (once its warmed up). The technique is just let off the gas completely, then apply just a little pressure until all the arrows disappear on the MFD.
