Old 12-02-2009, 02:37 PM   #53 (permalink)
Daox
Originally Posted by born2pdl View Post
How do you determine which burn rate your specific engine uses (moderate -vs- fast)?
Unfortunately, I won't be able to do that.
In the absence of that info, what I want to do is find some way of gradually opening up the EGR valve while monitoring mileage. Do a run @ 25% open, check mpg over that run, do another run @ 50% open and check mileage, rinse & repeat. I'll create some sort of load vs valve opening map and hopefully find some way of controlling the valve with it.
