Old 12-03-2009, 08:38 AM   #186 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Cherokee's DO RUN very hot. in fact they are designed to run just under boiling a 210'
they are just hot critters so adequate cooling especially in 125+ desert running is critical.
maybe you could use lesser fans if you used 2 of them? one in front and one behind the radiator? have one kick on at one temp and the other kick on at a slightly higher temp (this way if you need just a little cooling only the one will come on but when its really hot both will kick)
