Old 12-03-2009, 11:33 PM   #14 (permalink)
moorecomp
It has been a challenge trying to get good mpg's with the cold weather here. I finally removed the restrictor I had in the disconnected vacuum line, and am running it wide open and the fitting on the air duct open too. Today I got 39 mpg on the way home from work (52 miles) and it was about 25 degrees outside and snowing. Not bad considering I recently lowered the air pressure in my tires to their winter pressure of 35 psi. Gotta get my snow tires on!
