Old 12-04-2009, 11:00 AM   #11 (permalink)
mpvue
Originally Posted by rgathright View Post
Whoa... carb's are notoriously hard to increase FE due to their "always on nature".
I suggest installing a 2bbl carb with an Edelbrock Performer RPM manifold and a restriction plate. Essentially copy what the NASCAR guys use. Then you are going to want to install miles of cavernous (think the size of a 1" water hose), steel braided transmission cooling lines. The trannies get real hot and reduce your efficiency on those motorhomes. I assume you have a 400 or 350 power glide in there right?
I don't see why you'd suggest a 2bbl; a properly sized 4bbl will be ruuning most of the time on its primaries, which are smaller than the openings on a 2bbl. then, under load, the secondaries open up. a vacuum secondary carb only opens the secondaries when the vacuum signal drops, and this point is adjustable w/ springs.
years ago, I was able to tune my Dad's 460ci F250 for a few extra mpgs by putting a heavier spring in the carb; IIRC, he went from 9mpg to around 12-13.
even better than a carb in this application, there are myriads of fuel injection kits for chevy V8s, from simple TBI setups to full blown laptop programmable rail injectors.
as for the transmission, there are stout overdrive units available as well as modern computer controlled 4 and 5 speed automatics.
The Following User Says Thank You to mpvue For This Useful Post:
thatguitarguy (12-04-2009)
