Old 12-04-2009, 12:11 PM   #1 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Pre-warming diesel engine with glow plugs
I found some info about how my engine uses its glow plugs: the on time depends on the temperature of the coolant.
Temp. (*C)Time (s)
-3016
-105
00.5
100.25
180
400
Would it be worth while to somehow extend the on time, so that even when it's relatively warm outside, they still pre-heat the cylinder for at least 5-10s? Or would the drain on the battery be greater than the gains from having warmer cylinders?
Going along that line of reasoning, if a block heater and/or coolant heater were wired to run off of the electrical system for, say, 5 minutes after a cold start, then would the extra load on the alternator be greater than the benefits of shorter warm up time? I know, I know: the best is a plug-in block heater, but there are situations when you either don't have an outlet handy or don't have the time to plug in.
