Old 12-04-2009, 05:35 PM   #29 (permalink)
Chalupa102
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
I found that blocking the upper grill and part of the lower grill was best.
Originally Posted by Cd View Post
I'm wondering the same thing that Neil pointed out. Do you have the upper grill blocked? Usually it is better to block the upper grill.
I went with the suggestions and re-did my grill-blocking. I now have the upper grill fully blocked and the lower grill either partial or full, depending on the outside temps.
I also removed the trunk spoiler which is still a work in progress getting the trunk perfect. I should have it all complete by this weekend.
I removed the rear window vent visors and plan to do the same to the front ones this weekend as well. Hopefully the weather will be warm because it was a huge pain pulling off the rears in 35 degree weather.
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
