Thread: Took the plunge
Old 12-04-2009, 11:17 PM   #12 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by Formula413 View Post
There appears to be some sort of air temperature sensor down in front of the radiator on the driver's side, it might not be wise to cover it, but I don't know what purpose it serves.
I have a feeling it's not this simple, but does anyone know if you could connect a trickle charger to the traditional battery in the engine bay and be able to top off the main battery, or does the voltage converter not work in reverse?
That should be the ambient air temperature sensor, for the climate control. If it gets really, really cold out, it disables idle stop. So don't worry if the sensor ends up warmer because of your grille block.
The DC-DC converter does not work in reverse. You can grid-charge a Honda IMA battery, but you need a high-voltage, low-current power supply. When you hook one of those up, you bypass Honda's battery monitoring hardware, which would shut off charging in the event of a full battery or other problem.
A grid charger is on my to-do wish list, above a boat-tail but below rear view cameras. If you figure out how to make an automatic charger that you could plug in and forget, I'd love to hear about it.
There are a few folks on this forum who can grid-charge their Insights. 3-Wheeler and ericbecky come to mind.
