Thread: drag
Old 12-05-2009, 01:36 PM   #12 (permalink)
aerohead
are you
Originally Posted by 69chevelle View Post
Which is better fuel injection vs Carburetor for drag racing I guess from a eco perspective?
Are you doing a launch at redline,and then letting the clutch progressively lock up over the 1/8-or 1/4 mile? If so,then would it make a difference?
If the engine is throttling down the course,the "efficiency" of a duel-feed 4-barrel Holley/Edelbrock/Carter carb. might be approached with a multi-throttle-body EFI system,allowing,out-of-the-hole low end response and top end power.
Is that kinda what you're asking?
There are so many applications and possibilities it would be difficult,if not improper to make any general blanket statements.
