Originally Posted by JeepNmpg2
Based on what I've read, the boattail doesn't have to be SUPER strong, just structually sound and as rigid as possible, correct? My thoughts are if built correctly, it should be able to be completed under say 60 lbs or so including the steel hitch mount? Granted it's a custom application so far, but who's to say the general principals of the design couldn't be applied to other bluff-arsed suvs and hatches with hitch recievers?
Yeah,just strong enough is the ticket.That was Clarence"Kelly" Johnson's strong suit at Lockheed's Skunk Works.
Model airplane technology would suffice nicely.Glass over foam another path.
The receiver-hitch route gets you a couple of feet extra length out of the shoot.Great for any SUV!.And easy on and off.
If you can begin your taper over the back portion of the body even better.
