Old 12-06-2009, 01:48 AM   #346 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I found a actual ICE car that was out to set a new hydrogen recorded.
New Page 1
The tank has a Type IV rating and uses a plastic bladder wrapped with high strength composite graphite. The tank has a water volume of 87 liters and is rated up to 3,600 psi. At 3,600 psi, the tank holds 590 SCF of hydrogen, which is equivalent to 1.4 gallons of gasoline. At 200 HP, this tank is emptied in about 5 minutes.
From my EFI calcualtor an engine making 200HP at 13.8 A/F with a BSFC of
.37 will consume 6.2 lbs in five mintutes with a cost of $2.50 in gasoline.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Christ (12-06-2009)
