Old 12-06-2009, 07:03 PM   #29 (permalink)
88hf
EcoModder!
ratatouli - '01 honda insight
Today I've figured out all but the YEL RED wire in the large bundle.
I have two more wires ( one BLK, other WHT BLU ) to figure out from the square shock tower 10 pin connector ( connector has the large WHT BLK starter and large BLK YEL altenator wires. )
TomO, Do JDM civics have obdII ports or could I wire one up with my ecu? Also, there is no metal tab on that ground block, perhaps the larger black wire in the bundle went to a ground point?
