Old 12-06-2009, 07:56 PM   #32 (permalink)
TomO
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Update:
Here's what I have for the ignition harness:
Ign switch position - Color - Fusebox Fuse location
BAT - WHT/BLK (WHT) - to ignition switch (power feed to switch)
IG2 - YEL - #13 fuse 7.5A, #16 fuse 7.5A
IG1 - BLK/YEL - to ignition coil, #14 fuse 20A, #15 fuse 10A, #25 fuse 10A(pink wire for SRS power supply), #24 fuse 15A (red for SRS)
ACC - WHT/BLK - #23 fuse 15A (powers rdio/cigarette lighter and options)
ST - BLK/WHT - to starter cut relay (M/T) or neutral safety switch (A/T)
I'd send you the three pages this covers in my book, but Adobe Reader 9 has decided to override my nice little script that would just save some pages of my 1265 page Factory service manual.
Also remember that these are coming from a factory service manual for a 92-95 Civic, but it should give you a good reference as Honda doesn't usually change up the wiring much for ignition stuff.
Hope this helps
The Following User Says Thank You to TomO For This Useful Post:
88hf (12-07-2009)
