WOW. ok I think I am going to have to build one of these I am truly shocked it was THAT BIG and that big EVEN WITH the already in place Kamback improvements.
If your up for it (I KNOW its a ton of work) unless you already have the data?? ie what kind of improvement would JUST the tail make over a stock car? no belly no wheel skirts etc.. anyway to calculate that?
truly wow. Time to go find some coroplast!
I also wonder if I can test angles WITHOUT driving. IE big massive fan into a difuser array to straighten the airflow (think wright brothers wind tunnel)
I could aim the fan in the direction I want to test put a panel with tufts in place and adjust to see the changes in real time in the drive way.
do you think this would work?
